I can help with a couple of your questions.
The opening screen message is a Profile setting. You cannot change any Profile settings in ARC. Profiles can only be edited with Sentinel.
When you write to your scanner in ARC, a pop-up winodw appears. In that window, there is a Check Box "Enable GPS Location Control". You would check that box to turn on Location Control for the Favorites List, and then continue with the write process.
I can't find anything in ARC dealing with rectangles on Favorites Lists. All I'm seeing is circles. One point for the center and then the radius.
