Fayetteville Radio System
GMB951
Cumberland Co,NC
Does it mean anything now that Fayetteville has be redone as a simulcast system with new voice frequencies added.
trumpetman
Charlotte, NC
Nothing has changed with the actual system, the database was just updated with accurate information.
Only thing I would verify with your scanner is that Unidens have all four control channel capable freqs entered and GRE/Whistler scanners have all 10 voice channels input to properly follow the system.
GMB951
Cumberland Co,NC
yep, i knew they used the WFNC tower located in the city for their system, but they also added the viper towers in at Slocomb, and TWC,thanks
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Chris0516
Pittsboro, North Carolina
If not simulcast before, listeners may likely have a hard time bringing this system in if not using a Uniden SDS100 or SDS200...
Will that page be any help? Since I have the UBCD325p2. It says this:
"P25 Threshold option can be changed after monitoring the Site with Auto to see the best setting for that System to be decoded on
So, if decode is best at 6 in Auto, switch the P25 Decode Threshold for that system to Manual and 6. While 6 isn't a panacea, it's at least a beginning numeric to try starting with, typically up-to 9 in Manual mode will make the biggest difference. Not all scanners allow this ability System/Site specific/individually."
