FBI Frequencies
cookiend15
Banned
Hello fellow scanners,
I was just wondering if anybody happens to know of any good active frequencies for the FBI, CIA, Etc. for the Montgomery County New York area. I might be able to receive out of Albany New York however probably not much further than that. Please let me know if you know of any really good active frequencies for the above mentioned. Thank you kindly
DaveNF2G
Rensselaer, NY
The Albany FBI repeater is listed you-know-where.
Federal radio facilities are usually located only in major cities. If they're out of range, then they will use cellphones or satphones, depending on which agency and what equipment they have available to deploy.
10-95
Check out these frequencys as well:
170.950
170.025
173.175
173.125
172.150
173.050
173.100
