FCC finally goes after Baofeng
AK9R
Super Moderator
Central Indiana
According to the citation, the FCC has to issue a citation before they can issue an NAL.
tmfok7
Far Eastern Washington...
They need to all be banned! Just go to the top of this page and look at the specs for the TYT TH7800 that was obviously ripped off from Yaesu TX from 137-174 Mhz and 400-480 Mhz and it has a "voice scrambler" option! When did that become authorized?
ipfd320
Banned
W.Babylon N.Y. 11704
the voice scramble has been around for approx 5 yrs now--authorized i could,nt tell ya nothing is really clear lately as for the freq spreads thats always been like that for a long long time
baltimorecs
Baltimore, MD
Reading the citation the FCC cited them for the radio being capable of operating outside of the frequencies notes in their FCC grant and also at power above that stated in their grant.
I always wondered where they came up with the strange output wattage values in those grants.
bill4long
Indianapolis
Found this interesting item in today's FCC Daily Digest:
AMCREST INDUSTRIES, LLC D/B/A BAOFENGRADIO.US CITATION AND ORDER - ILLEGAL MARKETING OF UNAUTHORIZED RADIO FREQUENCY DEVICES. Amcrest marketed the UV-5R V2+ Part 90 transceiver outside the scope of its Equipment Authorization. Action by: Chief, Spectrum Enforcement Division, Enforcement Bureau. Adopted: 2018-08-01 by Citation & Order. (DA No. 18-801). EB. DA-18-801A1.docx DA-18-801A1.pdf DA-18-801A1.txt
https://docs.fcc.gov/public/attachments/DA-18-801A1.docx
https://docs.fcc.gov/public/attachments/DA-18-801A1.pdf
https://docs.fcc.gov/public/attachments/DA-18-801A1.txt
Finally some action by the FCC regarding the CCRs flooding the market.
The radios were capable of being programmed outside of Part 90 frequency specs. Why the FCC type accepted them in the first place is puzzling because they did pass the vetting process. At any rate, this is not going to materially affect the available of CCRs.
bill4long
Indianapolis
It’s about time...I’ve grown to hate those things. I’ve seen businesses illegally using those radios for a long time. Sent from my iPhone using Tapatalk
This particular incident is not going to change the available of CCRs in general, or this particular model (UV-5RA) in particular. It's a simple firmware tweak to fix any such problem on future production runs. (These particular models are not firmware updateable.)
baltimorecs
Baltimore, MD
That is something I have always wondered as well. I mean anyone at the FCC can simply look up these radios and see their specs and that they don't match the grant.
bill4long
Indianapolis
As I recall, the FCC's objection is that they have been advertising the radios for use in a service that the type acceptance doesn't cover. But, as I said, easy to remedy.
AK9R
Super Moderator
Central Indiana
I'm sure you know that the FCC does not actually review new products seeking FCC certification. The manufacturer or importer sends samples to an independent testing lab which tests for FCC compliance. The FCC then acts on the test lab's report.
True. I read elsewhere that the FCC action this week "banned" Baofengs. That's pure, un-cut, concentrated, Internet derp. All the FCC did was issue a citation to one on-line seller which means that seller has answer the FCC's citation in the specified length of time. We may see further FCC action, but there's no need to get the cart before the horse.
K7MFC
WRAA720
Phx, AZ
The most important take home point from this, and all the other related threads:
I suspect some didn't actually read the entire citataion before commenting? It was abundantly clear that the FCC had cited one single distributor, Armcrest Industries d.b.a. Baofengradio.us. If you read or inferred anything else beyond that, it's "pure, un-cut, concentrated, Internet derp" just like W9BU said. This is not an umbrella action against Baofeng and/or all other CCRs. However, I hope this will keep the CCR issue on the radar, and further action against more distributors of these radios will be taken.
RFI-EMI-GUY
I went to the website of the seller. They are pushing a radio called the ATR-22. While I was checking the FCC certs for this Part 90 radio, a chat box popped up. I asked if an FCC license was required and the seller said " I don't believe so". I then asked whether there were preprogrammed frequencies, and If so what were they. The seller replied that "software CHIRP will let you view, select and change frequencies".
Clearly, AMCREST does not want the buyer of these extremely cheap radios to be burdened by an expensive FCC license.
If these radios show up on a police channel or ham repeater near you, it will be because of their dishonest marketing practices.
Sent from my SM-T350 using Tapatalk
RFI-EMI-GUY
What the FCC should do is rescind the fraudulent
grant and tell the distributor to destroy the product. Actually US Customs could stop by and help with a steamroller.
bill4long
Indianapolis
Yep. And the test results are available online via this:
https://www.fcc.gov/oet/ea/fccid
The ID can generally be found inside the HT by taking the battery off, or on the sticker for mobile radios. The presence of the type acceptance ID on the radio is mandatory. (Sidebar: amateur radios only need be Part 15 certified. There is no such thing as Part 97 radio certification. Ham can use Part 90 and Part 95, or build your own radio, as long as it doesn't cause harmful interference. Commerically produced radios must be Part 15 certified, but this is a very general certification that pertains to just about every kind of radio, transmitters and receivers, and many other devices capable of some kind of RF radiation.)
Right.
I don't care what the people say, Baofengs and CCRs are here to stay. ♫
bill4long
Indianapolis
What the FCC should do is rescind the fraudulent grant and tell the distributor to destroy the product. Actually US Customs could stop by and help with a steamroller.
It doesn't work that way. The FCC has civil authority, not criminal, and no port authority whatsoever. They can render civil forfeitures for violations of FCC regulations, but they can't stand at the dock and turn the ship away.
bill4long
Indianapolis
I went to the website of the seller. They are pushing a radio called the ATR-22. While I was checking the FCC certs for this Part 90 radio, a chat box popped up. I asked if an FCC license was required and the seller said " I don't believe so". I then asked whether there were preprogrammed frequencies, and If so what were they. The seller replied that "software CHIRP will let you view, select and change frequencies". Clearly, AMCREST does not want the buyer of these extremely cheap radios to be burdened by an expensive FCC license. If these radios show up on a police channel or ham repeater near you, it will be because of their dishonest marketing practices.
Yep. Deceptive marketing is what this particular case is about.
RFI-EMI-GUY
US Customs would have the authority, they seized some illegally imported Range Rovers and crushed them flat.
bill4long
Indianapolis
Hehe, that would have been fun to watch. I'm no expert about the import situation, and there are probably laws on the books that allow customs to do whatever they deem appropriate.
wrath
I saw video of that amateur trump buddy Duarte confiscated 1 billion worth of illegaly imported lambos and such couple of bulldozers and made a very public show of reducing them to rubble .
Sent from my SM-T810 using Tapatalk
wyShack
Campbell County, Wyoming
I read through the order and the FCC appears to be taking exception to the Part 90 authorization. Part 90 radios should not be frequency adjustable by the user-that is you normally should only be able to select 'channels' that have been programmed. The idea is to prevent users of the radio from using frequencies not authorized by their license. Also the Baofengs can be 'programmed' for frequencies not authorized by Part 90-yet another no-no. I did not see anything related to output purity like spurious signals or high harmonic content. It apears they can still be used in the Amateur service -just not Part 90.
