kd7mxi
walmart etc are now marketing motorola bubblepacks with repeater capability ..sticker on back of radios ,,, fcc id:k7gmrcee
Amateur Radio operators who are authorized to design, build, and operate transmitters without equipment certification in the 420-450 MHz amateur band should be allowed to do so on the 462/467 MHz GMRS channels
IMHO half of GMRS should be de-licensed.
This is how I think it should be set up.
Keep the 8 FRS 0.5w channels as is (license free)
Remove the license requirement for the 462mhz GMRS channels and allow up to 5 watts.
Keep GMRS license requirement for 467mhz GMRS channels and allow up to 50 watts simplex only (forbid the use of GMRS repeaters going forward).
The reason I see this as the sensible solution is it would inadvertently make most bubblepack radios license free as most do not have the ability to transmit on the 467mhz repeater input GMRS channels thus licensed GMRS would require buying REAL GMRS radio's that do transmit on these frequencies.
I will admit to being new to the FRS/GMRS/HAM community, so please forgive my ignorance here. I can understand limiting GMRS equipment to the GMRS bands as licensee's with a call sign will not be able to use bands that you need to test to have access to. But why the limit on the HAMS that have tested and passed (technician covers these freqs I believe) the exam and their equipment that is capable of using these freqs? I have a basic entry level Baofeng radio that can recieve the FRS/GMRS channels as well as many others. I have FRS/GMRS "bubble pack" radios around my house for my kids to play with as well as for camping and what not. When the kids have the radios I lock in a FRS channel only and I monitor them as these are not "toy" radios and they can be heard by anyone near us tuned in. I monitor them with my Baofeng, I also talk to them with the Baofeng as well as I usually have that radio with me while I listen in on a local dispatch channel. I dont currently have a GMRS or HAM license, and I do not transmit on those freqs, I respect the law on that matter but I dont understand why my radio is not supposed to be used for GMRS if I was to hold the license.
Dom
How about a better idea.
1) Get rid of the FRS/GMRS bubble pack radios. FRS only bubble pack radios.
2) Increase the output power to 2 watts on FRS comparitable to MURS. Portable units allowed only.
3) Continue to require a license for GMRS use, up to 50 watts.
4) All FRS (as is) and GMRS must be narrowband (2.5 Khz) compliant to prevent bleed over.
5) All GMRS repeaters must be seprately licensed from a regular GMRS license.
6) Allow all part 90 equipment to be part 95 certified.
7) Enforce the laws. If not, then you have yourself anouther childrens band.
And until Part 90 can be used for GMRS I would personally never consider buying a GMRS license because if I did I would want to be able to use full wattage via a mobile in vehicle unit and part 90 commercial radios are cheaper and more readily available than GMRS only mobile/base radios.
The current way you are using your Baefeng on FRS is illegal in both cert type and in transmission. To get at least your transmission legal you need to install a attenuator on it to get the power output down to half a watt on FRS channels.
The only license-free transmission legal (but cert type illegal) communications a BaoFeng can do out of the box is MURS in low power mode and then also Marine.
MURS would not be legal since the power output can be increased beyond 2 watts. This is one of the limitations listed in the Part 95 rules that apply to MURS.
As for Marine VHF, they would need Part 80 certification. Do the Baeofeng's have that?
My antennas are removable. I have the UV-5R model. I guess I need to monitor and talk to my kids on my FRS radio then, I forgot about the power issue, as my Baofeng will not do .5W with out an attenuator. I dont transmit on any HAM freq yet, I'm not able to take my test until the 14th of next month.
Dom
I said MURS in LOW POWER MODE <--You need to read.
We already know this about marine? Baofeng has the ability to make marine band transmissions that comply with the transmission specifications/characteristics of the band. As I already said, it would be cert type illegal but transmission specifications/characteristics legal. Again need to read.
I guess my separation of cert type illegal and transmission specifications/characteristics illegal just flew totally over your head.
Dom
UV-5R eh? You're already behind the times, lol. It's already time to upgrade to a UV-82!
http://www.amazon.com/dp/B00F33W0FM/
It doesn't matter if you turn it down to 2 watts or less on the MURS frequencies. The FCC rules very clearly spell this out:
§ 95.649Power capability.
No CB, R/C, LPRS, FRS, MedRadio, MURS, or WMTS unit shall incorporate provisions for increasing its transmitter power to any level in excess of the limits specified in § 95.639.
For reference, here is the part of 95.639 relating to MURS:
(h) No MURS unit, under any condition of modulation, shall exceed 2 Watts transmitter power output.
Since these radios can be set to transmit with more than 2 watts, that makes them invalid for use on MURS.
The radio either meets the rules or it doesn't. It's not a pick and choose thing
Also:
95.655
(d) No transmitter will be certificated for use in MURS if it is equipped with a frequency capability not listed in § 95.632.
Since these radios are "equipped with frequency capability" other than just he MURS frequencies, they don't meet the MURS requirements.
There is no such thing as as this. It's either type accepted or it isn't. Being able to program a radio where it isn't legal to use doesn't change the fact that it isn't type accepted. The FCC rules are very clear on this.
I got this one cheap and I just purchased a BF-F8+ which should be here tomorrow. I went with the F8 since it will share the same battery as the 5R and has the same features as the UV-82 for less $$. After I get my license I plan on saving for a Yaesu VX-8GR. That is the plan anyway. I have my eye on a Kenwood tranciever one of my friends is thinking about selling as well. Unfortunatly where I live I cant put up an antenna... stupid HOA stuff.
Dom
