FCC White Paper Explores Deployable Emergency Communications System
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
Back up radio systems and redundant engineering. You have thought that this would have been started as a severly overt plan since the 60's, but I guess not.
Airborne relays, repater systems would not be a plausable explanation to a national catastrophy. The need for aircraft would be to significant, as well as needing antennas for multiple radio systems and radio bands / frequenys and ecetra.
Civilan and radio hobbiet, ham radio operators could mroe than well enough handle esential tasks as far as radio relay in most locations. The exception would be large metrolpolitian agencys like Detroit, Los Angelas and others.
Radio and communication administrators for Public Safety agencys need to look at this and look hard. Planning, devoloping, and fabrication of back up radio systems for their agencys concerned. Receiving input and ideas from subordiantes, agency heads( Fire& L/E ) , and radio service folks. A national emergency, catastrophic event, or an act of terrorism. Me. If I was a Department Administrator and had the funds, I would set one up for my agency. Somehow, but I would do my best to make it happen. I would take care of my own folks instead of depending wholly on county / state radios repeaters.
Can you have a rural backup repeater station, where the only thing you have to do is raise a portable antenna system, or have a winch / motor system to raise a moderately tall antenna system? The antenna hidden, or lowered to prevent damage? How about a backup repeater system, antenna and all, where all you have to do is turn on the repeater?
Is a company, or corporate entity willing to allow you to use their high rise, elevate building as a repeater location? Install the repeaters, keep the antennas hidden, raise them when needed. Gee whiz, how tall does the repeater antenna have to be on a high rise, or elevated building / structure?
Aircraft would be costly, and could not cover an entire area, and many would be needed in a multi-jurisdiction Multi-Casualty event / national disaster.. Weather could play a hazzard, and might hamper Public Safety communications due to lighting, clouds , rain - or other radio signal barrier. Public Safety agencys are not the military. Radio signals from portable radios might night reach the aircraft, whom is at at altitude to cover a large area, or at an altitude to prevent mountainous terrain from being a barrier for teh area they are covering.
Leave it to the Government and Homeland Security to screw up radio communications.
FF - Medic !!!
ff-medic
Banned
It's great to see this explored more. Civil Air Patrol has been using low power repeaters mounted in their aircraft to provided coverage in remote areas and to provide longer range coverage than teresterial repeaters are able to allow.
Here's just one article I found, and I'm sure you can find more though Google.
http://www.fws.gov/northeast/refuges/fire/pdf/CivilAir.pdf
Me, having been in the Fire Service for about 19 years ; I would think that not "Everyone" talked on the radio. I can see a Cessna, equipped by the " CAP' as being a airbone repeater, but not for multiple communications that semi-large or large Public Safety agencys need. Most comms on a fire scene are line of sight. How does California agencys handle their large scale brush fires that burn hundreds of acres, some without communications coverage?
" Teresterial repeaters." Boy, that is a nice term. Teresterial meaning......?
Mobile command centers could be deployed. If a fire scenerio for this location was not already pre-planned by agency leaders, then most likley something was wrong. Especialy if they fight enough wildfires/ brush fires. 4 wheelers, off road buggys with one person or a team, relaying " Essential" radio communciations, and keeping teh incident commander up to date with manpower location, tactics and other "Essential" information.
Don't make a situation anymore complicated than it needs to be.
FF - Medic !!!
