Fed Encryption
relicwr
It's P25. Go do a manual scan and go around the licensee's frequencies and you'll hear it. Is this on a trunked or just a conventional P25 repeater?
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
Conventional. On that freq., I have heard both P25 and analog traffic in the clear in the past. Also, its different from the other analog (analog signal) encryption I've heard on that freq. Tomorrow if I have time, I will try to dig up on older recording of the encryption sample. So far I have nothing more in length then I posted with that encryption.
SOFA_KING
SE Florida
I have never heard that type of data from P25. I have heard a full time data channel on the USCG, and seen the NAC to confirm it being P25, and it sounds nothing like that at all.
My guess??? Telemetry of some sort...maybe for remote alarming. The FBI used to have all sorts of stuff like that in the old days, but slower data rates.
What scanner was used?
mike_s104
Using a 396XT. It sounded like analog, so I set it to analog only and search for a tone...no CTCSS. Like I've said before, I'd heard both P25 and analog traffic in the past on the same freq.
Squad10
From the transmitter's hang time at the end of your recording it seems to me that 167.4375 is a repeater output. So what is heard maybe getting in through the repeater's input frequency. If you know the input freq. you may want to monitor it. It's strange that no CTCSS is being encoded, in all the FBI repeater interefence cases I've heard, either the 167.9 or EOM tones were present.
ecps92
Taxachusetts
I'm thinking Intermod
SOFA_KING
SE Florida
But if it is getting into the repeater, it needs a PL of 167.9. And if it is coming from the repeater, he should see the 167.9 PL on the scanner.
I say it is either on frequency data (not common, but I have heard the FBI do it), or an image on his scanner.
ecps92
Taxachusetts
So many variables, to make many assumptions.
Could be a Dual Mode Rptr [P25 and Analog]
Maybe someone left the PL of the RX side [happens routinely]
Squad10
It could be intended data on a frequency12.5kHz either side of the repeater input resulting from poor or no frequency coordination.
This happened for years on an FBI repeater input of 165.9000 analog, ATF's channel 5 simplex 165.9125 analog CSQ would often interfere causing the three associated FBI repeater outputs to transmit semi intelligent voice with 167.9.
Anybody know the 167.4375 repeater input frequency?
Wondering if it might be FAA telemetry data audio.
mike_s104
Again, in the past, I have heard P25 in-the-clear and encrypted traffic as well as analog in-the-clear and I believe encrypted (it sounds almost like static except for the squelch tail like in this sample). It is a repeater output.
So Far Away....
telemetry,you mean this sort of deal-e-o..
http://www.philly.com/inquirer/busi..._new_satellite-surveillance_radio_system.html
the newly online sat system for aircraft?
n0nhj
In way too deep...
Lakewood, WA
Could also be OTAR data.
(Over the air re-keying) Changing the encryption key on a radio.
They would send it without PL so the users wouldn't hear it.
Chuck
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
brandon
SoCal
I used to hear something similar (although not quite the same) on a US Customs frequency in San Diego back in the analog days. Not P25, Not OTAR, just some kind of digital noise and showed up with the 100.0 PL. Wish I had a recording of it still.
Speaking of federal encryption... this is my favorite type :D
