nmfire10 said:
Narrowband in simple terms:
Each "channel only uses 1/2 as much bandwidth, making room for more channels. Logically, 1/2 as much bandwidth used means twice as much available as before. Once everyone is narrowbanded, it effectivly doubles the number of available channels to be licensed.
Not quite. Let's define some industry standards first.
Wide FM = +/- 75 kHz deviation, or about 200 kHz bandwidth.
Standard FM = +/- 15 kHz deviation or about 40 kHz bandwidth.
NarrowBand FM = +/- 5 kHz deviation or about 16 kHz bandwidth.
SuperNarrow FM (AKA SNFM) = +/- 2.5 kHz deviation, or about 11 kHz bandwidth.
Of these four, Wide FM is used by FM and TV broadcast. (that's about it)
Standard FM is almost extinct, being used by a few hams as links and by the military.
NarrowBand FM is used by nearly everyone, and has been for the past 30+ years when the switch was made from standard FM to NarrowBand FM. There are even some transceivers out there marked "Converted to NarrowBand FM - 5 kHz".
SNFM started showing up a few years ago and is used on the new "7.5 kHz channels" on VHF (such as 155.1675 MHz), and on some 12.5 kHz splinter channels (as well asa few standard channels) on UHF. It is called narrowband FM by some manufacturers, but that does little but confuse most users - especially those in the industry and those who have been around when NBFM came into wide use in the 60s. It is unfortunate that one scanner manufacturer has chosen to use the term 'NFM' for what is really SNFM, and FM for what is NBFM, but everyone can see the confusion that is causing.
When the switch from FM (40 kHz BW) to NFM (15 kHz BW) was made in the 60s, it more than cut in half the bandwidth of every signal. As you can see, going from NBFM (16 kHz BW) to SNFM (11 kHz BW) does not yeild a doubling of the available frequencies per se. At best, it gives you nearly 1/3 more spectrum. Of course, the problem is that until all the users convert from NBFM to SNFM, NBFM users will greatly interfere with operations on SNFM channels.
Things are bad enough trying to use 16 kHz BW signals on 15 kHz BW channels. Many people know this listening to scanners and hearing strong adjacent signals blead over to the channel they are trying to monitor. But, they will be much worse when (or IF) the conversion is complete and people are using 11 kHz BW signals on 7.5 kHz BW channels. Someone does not know simple math at the FCC, I guess. :roll:
While I would agree with your " it effectivly doubles the number of available channels to be licensed" statement, since there will be (actually already ARE on VHF High Band) twice the number of channels available for licenses, it does NOT double the available spectrum. Someone is using 'new math' on the radio spectrum. As I have shown above, you will have about 1/3 more spectrum. The difference will be 'shared' between adjacent channel users in the form of adjacent channel interference.
Joe M.
