Federal Medical Center Devens
tip
North Central MA (FN42eo)
Anyone know if the info in RR database is up to date for Federal Medical Center Devens?
I downloaded using ARC96 via RRDB to a RS Pro-2096, and when scanning, get no hits. However, when I manually go through the frequencies, it seems the control channel is 408.250, which doesn't agree with the database, and I get some voice activity on the other freqs.
Here are the freqs I have loaded (what I found in the RR database):
Red (c) are primary control channels | Blue (a) are alternate control channels
406.8125
408.250c
408.250
409.0125
409.4125a
Anyone close enough successfully monitoring this site?
Thanks.
Tom
ecps92
Taxachusetts
I was out there last fall and the info was still Valid.
408.2500 wast one that popped up with some Voice, but I could not confirm it as an image or real, during my trip. Guess it's a new member of the TRS
406.8125
408.250c
408.250
409.0125
409.4125a
Thanks.
Tom
tip
Thanks. I will be right around the corner from there all night tomorrow night, so will bring the pro-96 and see what happens when a little closer.
ecps92
Taxachusetts
Could have been quiet, but, depending on the time
I would think you would hear
a. Shift-Change Radio Checks
b Lock down order
Never been out that way during the over night, usually day shifts
It was overnight.
tip
I did do a conventional discovery on the range of frequencies that are published for this system on my HP1EX, and do get lots of radio traffic.
Traffic picked up on 407.4125 and 408.8125 that was in line with that type of facility.
Just need that band plan!
