Feed Keeps droping every few minutes please help
holweger23
Wahpeton, North Dakota
Interesting.
Mine drops about every two days at random times. It generally only drops once and for only about 10 seconds, but it's the same error that you're receiving.
Yes it is yesterday it ran for 18 hours then starting at 3 it only works about 70% of the time nothing changed. I have no clue
n6dcr
Mine started doing the same thing this afternoon, it's been fine for a while, same server as yours audio9
scottb908
Terryville CT
ping test
I always suggest this to people who are having potential wifi issues.
Open up command line
type : Ping <ip address of your router> -t
that will do a continuous ping so you can see if your connection to your router is dropping.
Since you can open more then one cmd window do the same thing to your feed address as well.
If you see it drop on the feed address and not the router issue that means you have a problem with your iso, If it drops on your router ip then you might have a wifi issue.
you can leave these pings going overnight to stop the ping hit CNRL - c it will give you stats of how the ping did.
