Planning on purchasing an AirSpy HF+. I have antenna picked out but antenna has PL 259 connector. Anyone know where I can get 50 feet of feed line with the required SMA male connector to plug into the AirSpy HF+?
I'd strongly recommend not try to connect RG-8 or LMR-400 directly to those type of small radios. It'll put a lot of stress on the SMA connectors.
Common industry practice is to use a smaller jumper to make the final connection between the heavier coax and the device.
A short jumper of RG-58 and the connectors will work just fine and will not have a noticeable amount of loss. It'll take the stress of the SMA connectors.
Custom made cables:
https://www.theantennafarm.com/cata...e-assemblies-344/rg-8-lmr-400-9913-cable-395/
Get the SO-239/female UHF connector on one end to match your antenna, and put a female UHF or N connector on the other.
Then just get yourself a male UHF or male N to male SMA jumper made out of RG-58 or similar cable to make the transition.
