Feed showing online, but unable to connect
emt_531
Hi, I have a feed that for two days now is showing that it is online, but when you try and connect to it, it says that it is offline. I have had to stop and restart ScannerCast both days. What could be causing this?
Eng3ineer
Southwest Arkansas
Are you using the player that pops up on broadcastify???
If so this has been happen to me as well over few days. The feed shows online but when try to play the feed shows an X and player never starts and it's been random off and on my on all my feeds.
I downloaded scanner deluxe for my iphone so when this happens can pull up the app and see that feed is fine and still online. Also might give Radiofeed a try it just as easy to use as scannercast and it has log at bottom of feed that shows when feed is offline or connected unlike scannercast.
Radiofeed can be found here ProScan
ffexpCP
wizard of odd
Michigan
I've been having the same issues. Scannercast shows connected / online, and the web shows it online, but it will not play half the time.
