We bought a small fiberglass motorhome. Adding a sufficient ground plane is not easy as there isn't enough free flat space on the roof.
So this leaves me with using a no-ground plane antenna.
For ease of install, there's the side mirrors. For added height, I could travel the distance (under the carriage) to the rear where there is a ladder I could attach it; bu then I risk taking it out at underpasses and trees.
I do not want to drill the fiberglass as there is no easy way to put a proper backing plate w/o tearing up the interior.
So I think that leaves me with the only real place of the mirrors. I have been partial to ugly firestik antennas, as (for me) they have proven to take abuse on my 4x4 rigs; but I have never used their no-ground plane antennas.
Does anyone have experience with any no ground plane antennas?
I know dual antenna's offer more "directional" -- I am more interested in trying to get out in all directions (realizing that the RV itself will block some); will dual antennas result in less coverage in side-to-side directions than a single antenna? Or will duals just result in more forward-rear direction coverage?
I seem to recall an experience that a dual antenna resulted in more forward/rear coverage and less side to side coverage, but can't locate anything to back that up.
Basically, if a single antenna gets out "in general" as good as a dual antenna, simple is better... but if dual antennas provide direction AND additional coverage, then I'll go that route.
Thanks.
Thanks.
