Field programmable uhf for a newbie
longderunner
new york, usa
Hello all, I firstly apologize for any ignorance I have, this is quite new territory for me.
Im looking for a field programmable motorola UHF radio (for headset, 2-pin) for scenario paintball/airsoft uses. Its going to be used primarily on the FRS frequencies, but I need a UHF unit for clarity/wattage/range for emergency and in-game purposes.
I know that I need the 400-470 band, 12.5/25 stepping? and CTSS so Im fully compatible, and I need to be able to select frequency without using a computer and software.
Im just wondering what my options are, without breaking the bank, obviously this is going to be a used model. Ive seen the gp68 and gp380 (which i believe isnt field programmable) on ebay from those sketchy sellers, and im not too afraid of going with them, but I definitely want to be better informed. Any help would be really appreciated!!!
KG4INW
Midlothian, VA
First of all, it would be illegal to use any radio that was not specifically made for FRS use. You're limited to 1/2 W and a fixed antenna, among other strict stipulations. The JT1000 is an excellent Front Panel Programmable radio made by /\/\ (in VHF and UHF) but you're still not allowed to use them on FRS.
Have you considered getting a GMRS license? It'll give you more flexibility in radio options and be legal.
longderunner
new york, usa
Oh wow, Im sorry I wasnt even aware that it was illegal, as basically everyone I have talked to does it. In that case the GMRS would be my option, but luckily does not change the radio choice.
The jt1000 looks great, and I dont mean to scrape the bucket but is there anything else thats a bit cheaper than that? I dont need any complicated features, just good power, field programmability, the UHF range, CTSS and a 12.5/25 stepping. Which is why the gp68 looked decent, but at the proices I see them for something seems off, one of those "too good to be true things."
KG4INW
Midlothian, VA
Well, I don't know much about the GP68 (especially the ones from Hong Kong) but there are several threads here that should provide you with a lot of good info. Just search the forum and see what turns up.
As for other recommendations, the GP2000 would also fit the bill but once again, I don't know much about them. Any other Motorola FPP capable handhelds will definitely not be cheap (e.g. XTS2500 or XTS5000).
cmdrwill
So Cali
Actually you can not use any radio on GRMS that has front panel programability.
§ 95.645 Control accessibility.
(a) No control, switch or other type
of adjustment which, when manipulated,
can result in a violation of the
rules shall be accessible from the
transmitter operating panel or from
exterior of the transmitter enclosure.
gewecke
Banned
Illinois
This will suit your needs AND be legal.
Motorola T 7200 gmrs/frs 2 watt simplex or repeater capable.
n9zas
KG4INW
Midlothian, VA
Ah, thanks for clarifying.
