Finally....a Motorola Talkabout FRS radio WITHOUT companded audio
n1das
Nashua, NH
I keep a few FRS radios around for occasional light casual use, especially when my young nephews come for a visit. Even though I have higher end commercial radios for GMRS and ham use, I keep a few FRS radios around to have as disposable radios and for my nephews to play with.
One thing about the Motorola Talkabout FRS radios and Motorola's analog business radios is they use companding on narrowband channels. It is an audio enhancement feature to try to improve the audio S/N ratio. Motorola claims it helps the audio sound "clearer" compared to other radios. Motorola calls their companding system "X-Pand" and implemented it across their product lines. With Motorola's top tier radios, the compander can be enabled or disabled per channel. On the Motorola Talkbabout FRS radios and business radios or business bubble packs as I like to call them, the compander is always enabled and there is no option to disable it. Motorola went all in with companding on narrowband channels in their low end radios.
Motorola's X-Pand companding system generally works as advertised but it requires ALL radios talking to each other to be companding their audio for all radios to sound right. It's an all or nothing type deal. Problems arise when some radios talking to each other don't compand their audio. The expander in the Talkabout's receiver expands audio that wasn't compressed originally and blows it apart, resulting in muffled and distorted audio. The Talkabout's receive audio overall sounds like 'expletive' when this happens. It sounds like somebody stuffed a sock in the speaker. This is what Motorola's crappy and much hated X-Pand audio companding system tends to sound like more often than not. Motorola could really clean up the audio on the Talkabouts and business radios if they provided an option to disable the compander. Use the compander if ALL radios talking to each other are companding their audio, otherwise don't use the compander at all.
I found a couple of Motorola Talkabouts don't have the companding feature like the others have. The Tx/Rx audio is a world of difference better on these radios. One model is the T600 waterproof radio. I recently picked up a few of these and was pleasantly surprised to find this model DOES NOT compand the audio. Yay!! The Tx/Rx audio sounds pretty good compared to my commercial radios I use on ham and GMRS. The Talkabout model the T600 replaced (MS350R) also did not compand the audio.
Just thought I would share what I found about the Talkabout T600 waterproof FRS radio. :)
