Finally decided to go for my Technician License
Houston, Texas
Been a while since I last posted on these fine forums. Something called real life & my photography hobby has kept me busy, especially since I got a new mirrorless camera:D
Anyway, before I get too carried away, let me get to the topic at hand.
After having my GMRS license for nearly two years (October 2024 is when I got my GMRS license) & doing quite a bit of thinking, I have decided to reverse my previous stance and take the next step and go for my amateur radio technician license.
I will be using HamRadio Prep to help me study, as I found this was the best option for me.
I tried to use Hamstudy.org, but I found their website to be a bit more convoluted to use in comparison to HamRadio Prep (Not knocking hamstudy at all them at all, just what I found based on my personal experience).
If anyone has any advice on how to further improve my chances of passing the exam on the first try, I am more than open to receiving them.
K4EET
Chaplain
Severn, Maryland, USA
Hi @Aviation_Scanner and that’s awesome that you have decided to get your Technician license in the Amateur Radio service! I’ll give a second shoutout to the Gordon West series. Keep us posted and let us know if you have any questions. 73, Dave
Houston, Texas
Unfortunately, book study and my brain don't get along :LOL:
HamRadio Prep breaks things down to the point I can grasp the concepts being presented and if I have further questions, google USUALLY has the answers (emphasis mine).
I am sure I'll be reaching out here if I have any questions along the way.
D31245
FN42
Some good advice in your previous threads:
ladn
Congratulations! You're on the right track.
Assuming you're active in the GMRS world, that experience will help you grasp some basic ham radio concepts.
We all learn differently and you seem to have found a mode that works for you. Try to learn not only the questions and answers, but the reasoning and science behind the concepts covered in the questions.
When you've covered most of the material, start taking the online practice tests. When you're regularly scoring in the 90% range, you'll be ready for the real thing. You may also want to check around as to what groups offer testing and how their tests are administered. In the testing sessions I've encountered, you'll get a question packet (usually a couple of printed sheets stapled together) and then answer by filling in the multiple-choice bubbles on another sheet. Some groups may use "Scantron" answer forms which are designed for machine scoring.
When you pass your Technician test, the testers will usually give you the opportunity to then take the General test at no additional charge. You should avail yourself of this opportunity as the General question pool isn't that much different than the Technician and you have absolutely nothing to loose by trying and a General license will open up even more ham radio horizons.
Good luck!
73
Houston, Texas
I try to be.
I was also a volunteer firefighter before I even got my GMRS license and have a very basic and rudimentary understanding of how repeaters and simplex channel works, so not sure if that knowledge will transfer to the technician or general exams.
That's what I have gemini for (Google's AI), although if I am still not sure, I will verify the info here on these forums.
Good luck!
73
I am going to stick with technician for now, as I get too overwhelmed if I am taking more than one test and if I am presented with too much information.
ladn
I take it by that statement, most who study for their amateur radio license just study the questions and answers and not the science & concepts behind them?
Unfortunately, yes!
There will be some questions that may make absolutely no sense, and for those, just memorize the answer and move on. Bust most questions, especially on the Technician test, are worth the effort to understand the concepts behind them.
AK9R
Staff member
Super Moderator
Central Indiana
Everybody learns differently.
I came into amateur radio with a technical background, but no formal training in electronics or radio. I bought the "Now You're Talking" study book which has now been replaced by "ARRL Ham Radio License Manual". I went through the entire question pool in the back of the book and answered each question without prior study. Then, I "graded" my test using the provided answer key. For each question that I got wrong, I dug into the book and read the applicable section of the book to understand the correct answer. With that level of studying, I passed the test. That method worked for me, but I'm not saying it would work for you or anyone else.
Keep in mind that there will be 35 questions on the Technician test taken from the hundreds of questions in the question pool. You only have to answer 26 questions correctly to pass the test. I know that some people use the online study tools and get hung up about not getting a perfect score on the practice tests. Don't let that deter you.
However, I'm going to be blunt. Given the number of comments you've made about getting your amateur radio license, I think it's time to just do it. Stop trying to find the perfect study method or coming up with reasons to not go take the test. Fish or cut bait. Cook or get out of the kitchen. Take the test.
Houston, Texas
The main reason I was going back and forth, which I have never mentioned until now, I suffer from Autism Spectrum Disorder level 1 (Which used to be call high functioning autism).
Sometimes, I think to myself learning something new is too difficult when in reality, I just needed to just buckle down and study/learn.
The above is exactly what happened to me & I now realize, I just need to get on with it instead of imposing self doubt on myself.
K9KLC
Southwest, IL
Go for it. You can do it. I know several people in your situation and they're actually having a blast on the radio.
eagle2046
Eugene, Oregon
I wish all you guys luck on the exam. I had a tech license when I was 11 years old, had to do morse code but I passed. I am 72 years old now and I don't remember anything about radios. I went to school and earned my B.S. in Electrical Engineering so that may be a help, but I also don't remember any of that. Good Luck guys !
ecps92
Taxachusetts
in addition to the many study guides/manuals, maybe reach out to your local club as they maybe running in-person or on-line classes.
I know of this one that is open
A free, weekly, live, Amateur Radio Technician Class Licensing course on Zoom will begin on Thursday, Sept 3,
and will run through Thursday, October 15 (7 sessions).
The three-hour sessions will start at 6:30 PM Eastern Time.
These are the classes that we have been holding for years sponsored by the National Electronics Museum.
. Those wishing to sign up should
email roland.anders@comcast.net.
Rol Anders, K3RA roland.anders@comcast.net
Racklefratz
I just was reading posts on the QRZ forum today about 8 year-olds passing the Technician test and becoming licensed hams.
What does that tell you? What it says is, just get pretty much ANY test prep guide, and there are many out there, read it, and take the test.
I've been licensed 66 years, and in those days, passing amateur licensing tests took serious dedication and effort; it was an achievement to be proud of. Now, FCC has dumbed down the tests trying to prop up the hobby, and anyone can effortly pass them. A ham license doesn't carry nearly the prestige it used to.
