findig lcn's
hawk51
Lapeer, MI
trying to program LTR system in Michigan, Tuscola County.
is there a place to find frequencies with LCN's
I found the wiki and it is very informative and i will use those methods, but i was just wondering if any of you fellas have already pioneered this system.
loumaag
Silent Key - Aug 2014
Katy, TX
Thread Moved
Please post such regional questions in the appropriate regional forum. Do Not post scanner questions in the professional/commercial radio section of the forums.
diskmonger
Michigan
Umm, Tuscola County is LTR Multinet. There is not a scanner on the market that can trunk track that type of system.
hawk51
Lapeer, MI
my 396t is scanning it as we speak.
I am not catching all of the conversation, but I am getting about 90% of it.
I am scanning it as a conventional system and it seems to be working.
rdale
Lansing, MI
Correct. You asked for LCNs, and that doesn't matter because you can't add the LCN's and cannot trunktrack this system.
hawk51
Lapeer, MI
after i put in the frequencies, the scanner asked for the LCN. what i didn't know was the LCN didn't matter what it was. it just had to be 2 digits.
i thought the LCN had to match the frequency...im such a newb
a29zuk
SE Michigan
The 396T LTR setup will only work on an LTR Standard System not on an LTR MultiNet System. That is why you need to scan it in a conventional mode. If you were to set up a LTR Standard System you would need to assign each frequency an LCN for the scanner to decode the system properly. I have never tried to listen to the Tuscola Co. system but from the explaination given in the database it looks like the control channel is used for both data and speech. Therefore, as in the explanation, you need two scanners to listen to all of the conversations.
Happy Monitoring,
Jim
