Most scanners have the capability of doing a search type scan , in which case the radio is tuned to each frequency in a band skipping to the next channel based on the channel width and radiation mode of the band, such as 12.5 khz for narrow band FM.
If the scanner locks on because a channel is active, my scanner saves the frequency in a list then, if the signal drops, moves to the next channel and resumes scanning.
Some scanners can move on to the next channel after a user-specified delay if the signal continues to break squelch, while others require the user to press a button (such as lockout) to continue. This gets around the problem of transmissions like ATCS BCP which intentionally are a pure broadcast rather than half duplex flipflop where the signal starts and stops regularly.
I have both a bc-125at and an sds100 that both have a search capability.
Hope this helps.
Erich
