BOBRR
Hello,
Have ProScan working thru the Serial Port. HAVE A SDS 200 (W10 PC)
Want to try to set it up using the LAN Ethernet connection.
Guess i need the IP address of the scanner.
Where do i find it, please ?
I did find the Menu: Show IP's", but I expected to see something like, e.g., 192.168.1.xxx
But i don't.
There is a LAN Mode: Disable
I thought the IP address is hard wired into the Scanner.
Is this true ?
Or, do I first have to wire the Scanner to Router Ethernet cable before it shows ?
Or, should i change (how ?) the Disable next to the LAN Mode ? Or,...?
Thanks,
Bob
But i don't.
Is this true ?
Thanks,
Bob
