Finding Motorola UHF frequencies?
tennesseefreq
Seymour, TN
I know this has been brought up many times in the past. I just want to get the facts and find out if this can be done without Trunker? If so how? So if you have links, or you can point me to previous posts that would be great!!!! Thanks for the help in advance!!!! Any and all details would be greatly appreciated.
Joseph11
Try running the known frequencies through the FCC Database.
BLAZER99
Links for the FCC Database:
http://gullfoss2.fcc.gov/cgi-bin/ws.exe/genmen/index.hts
http://svartifoss2.fcc.gov/reports/index.cfm
Both will give you frequency information except that the first site listed is no longer being updated as of about a month or so ago. However, it will sometimes, for some reason, give you a more complete current list of frequencies for an agency. I suggest you check both sites. Use the Licensee/State section on both sites. For trunked system frequencies you will see one of the following codes under or next to "Service" or "Radio Service": YB, YG, YS, YU, YW, YX. Those codes will tell you that the frequency is part of a trunked system.
On the first link where the three dots are (exe/...enmen/) it should be exe.genmen/ but it won't print up that way on the post. HOWEVER, if you click on the link as it appears, it will bring you to the site. I attempted to correct it but it will not show as genmen. Weird.
tennesseefreq
Seymour, TN
No, I mean a Federal 400Mhz Trunked system sorry. I'm talking about how you have to find the base the offset and all that.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
RRWiki has some info on your topic.
Edit: BTW, Eglin has formally ask to be excluded from publishing info regarding their 400 system on these pages
tennesseefreq
Seymour, TN
Yes, I know.... I already know there system from someone else. I need to figure out how to get this info without using trunker and if not then I guess i have to use it.
