Finding non ARMER frequencies/businesses related to them...
Jennifer_rose
Minnesota
Was wondering the best place or how to find if an analog frequency is in use and who uses it in a given area. As an example I hear traffic on 462.3250 in the St Cloud region. I have not been successful in finding out the business using it (dock operations for a trucking/loading company). Just curious as to some of the businesses associated with things I am hearing and knowing how far away they are.
I was browsing the This and the FCC site. Here they wanted a paid subscription to access some info. Since I am not sure how populated or outdated the info here is I dont want to risk the cost. The FCC was not the easiest to navigate and I was not able to narrow down the business on the above frequency.
Just curious, nothing life or death.
natedawg1604
Colorado
I believe you are looking for the FCC ULS database. It's often best to use the "geosearch" feature, this helps you filter by geographic location of a radio site. It's totally free to use.
Well, using the info you provided:
Frequency: 462.325
City: St. Cloud
State: Minnesota
It's likely these guys: ULS License - Industrial/Business Pool, Conventional License - WQEG986 - Bluestem
As @natedawg1604 said, the FCC database is a good option: License Search - Advanced License Search
Using that database search page can be a challenge. You need to know what info to put in, what info -not- to put in, and sometimes you have to dig through a lot of licenses to find the right one.
And then you run into the challenge of either finding wrong info, or not finding anything at all. While it would be ideal for all users to be licensed, that's not always the case. Not uncommon to not find users simply because they don't have a license, their license expired, or they moved and never updated it. Reading the license info can be a skill, also. There's a lot of info to digest, but it's not too hard. Click on the "Frequencies" tab and you'll see some good info.
The Radio Reference database can be hit or miss since a lot of it relies on user provided info. Not uncommon to not find what you need there. But, if you can positively identify a user, it's good to submit that info.
Jennifer_rose
Minnesota
Thanks, looking it up...
Frequency: 462.325
City: St. Cloud
State: Minnesota
Probably is, Thank you. St Cloud is an interesting region. The city is in 3 different counties so searching for stuff can be more challenging. I have been searching the business bands in the 400+ range recently. Figured it would be easier to look up info on a given frequency though. Guess I will need to learn to navigate the site that both of you posted. Thanks for the replies.
If you ever want to trying finding things and see some cool stuff on a map with advanced search features try this site maprad.io shows EVERYTHING! Its quite a powerful search tool
bearcatrp
Land of 10,000 taxes
You folks scanning for frequencies turn on all your services in a gives set of frequencies or just target frequencies that use DMR and NXDN? Am getting ready to start logging once I decide how I want to do this. Already have the DMR upgrade. Debating on getting NXDN before I start this. Figure using small frequency ranges and work my way up. Finally got my coax into the house recently and bought a mini circuits FM filter.
