Trunked systems are archived right here on the site
Yes...and also, maybe.
Systems that are no longer active are set to deprecated status, true...however quite often they are incomplete. What I mean by that is as system are slowly being shut down or migration to a new system has begun, we often remove sites and talkgroups that are no longer valid. The end result might well result in the skeleton of what was once a much larger system in the RRDB.
The New Jersey State Police Type II system, for example, took over a year to finally shut down. In order to prevent users from downloading sites and talkgroups that were no longer active on that system, sites, frequencies, and talkgroups were removed bit by bit over that year or so. The system you see in the deprecated section now is not an accurate representation of how large the system once was.
