Hi, Im trying to find out how many calls a system can have at once, so figured i can just look at how many fdma channel frequencies a system has/uses (and x2 if it phase 2 tdma). Now i can monitor the system and just write them down, but you wont know if there are some spare that are not commonly used but might be when higher traffic.
Im using sdr based tuning with linux and windows. In sdrtrunk it does output the following data but i cant seem to correlate it to the active channels i find it uses. Maybe there is better software for getting these details? or maybe its just not available. As even a neigbour site well within range of this one shows the same frequency band plan, so it must internally know what channel frequencies to use differently to the one below to avoid conflict.
Code:
Activity Summary - Decoder:P25 Normal (C4FM)
Network
NAC:xxx WACN:xxxx SYSTEM:xxx LRA:0
Current Site
SYSTEM:xxx SITE:xx RF SUBSYSTEM:3 LOCATION REGISTRATION AREA:0 STATUS:ACTIVE RFSS NETWORK CONNECTION
PRI CONTROL CHANNEL:4-1162 DOWNLINK:xxx UPLINK:xxx
SEC CONTROL CHANNEL:4-1082 DOWNLINK:xxx UPLINK:xxx
CURRENT DATA CHANNEL:15-4095 DOWNLINK:0 UPLINK:0
Neighbor Sites
xxx
Frequency Bands
BAND:0 FDMA BASE:851006250 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:-45000000
BAND:1 FDMA BASE:762006250 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:30000000
BAND:2 TDMA BASE:851012500 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-900000000 TIMESLOTS:2
BAND:3 TDMA BASE:762006250 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:600000000 TIMESLOTS:2
BAND:4 FDMA BASE:412475000 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:-9450000
BAND:5 FDMA BASE:420000000 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:5200000
BAND:6 TDMA BASE:412475000 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-189000000 TIMESLOTS:2
BAND:7 TDMA BASE:420000000 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:104000000 TIMESLOTS:2
BAND:8 FDMA BASE:467512500 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-10000000
BAND:9 TDMA BASE:467512500 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-200000000 TIMESLOTS:2
