Finding weather freq.
jaxbarney
I received a new uniden model 95 today and have been trying to access weather. It comes with preprogramed service search-weather bank. No luck getting any weather freq. I know I live in Montana but I should be able to get weather!. Any suggestions?
jaxbarney
Montana Weather
Thanks for your reply. I did finally figure it out. We are out a ways and can get the freq. but it is not clear. Thanks again Doug
kg4ojj
Crisp County, GA, USA
I use National Weather Radio stations to assess how well one antenna works compared with others. It's a great tool for checking out your radio & antenna in a new house or hotel....
You may need a better antenna than the antenna provided with your scanner. The metal telescoping or short multi-band antennas don't give you the best signal, if listening remotely. Check out the other forums or do a search for "antenna," as needed.
A weather radio (or wx-alert enabled scanner) should be as mandatory, for any home owner or renter, as a smoke/CO detector and a fire extinguisher......IMHO.
Enjoy the new scanner!!!
