what cable did you use to run down the wall? I'm thinking about taking LMR400 from the antenna through the attic to just above where i want my cables to drop and switching to something more flexible.
That would probably work quite well.
I had to install a satellite antenna for a portable terminal in our EOC a few years back. The antenna is mounted off the side of the building and I ran LMR-600 inside to the EOC. I terminated the LMR-600 inside the wall with a right angle connector and installed a faceplate with the connector on it.
When the EOC gets activated, the guy who runs the satellite terminal just plugs in a short jumper into the faceplate.
You could do the same thing. Get a large 12" x 12" electric junction box, most big hardware stores will sell them. Route your coax down into the box. On the cover, mount a bunch of Type N chassis connector and terminate your cable on those. Ground the box while you are at it. All your radios would plug into the jacks on the cover.
