I'm guessing the Fire Tone Out is measured and not using standard tones.
I get different readouts for the same fire company (single dispatch)
I'm also using Com Tekk Multi Decoder on my PC, and I have that set to standard tones, and the readings are always right on the spot.
So If i programmed my local fire tones into the 436HP, but the scanner is decoding them by measured, chances are it wont alert
Is there a way to have the 436HP just use standard Motorola tones?
