Firestik
Delivers1234
Monterey, CA
I saw this on a mini van.
JayMojave
Mojave Ca
Hello All: Well that looks like a good antenna installation, they have drilled holes into the top and used a after market puck or mount for the antenna. And in the center of the top of the car, which is the way to go.
Antenna installations like this one usually need a back plate of Aluminum or Steel to help support the thin sheet metal of the car. A sheet metal piece say .061 to .1 inches thick mounted in between the cars inside sheet metal and mounting screws or bolts. Some cars have real thin sheet metal.
Looks like it will get out really well. The photo doesn't show the top of the antenna but antenna photos aren't the easiest thing to take a picture of. Good going.
Jay in the Great Mojave Desert
Delivers1234
Monterey, CA
Hi. How would the sheet and what size be mounted to the roof? Do u add bolts through the roof to the sheet?
JayMojave
Mojave Ca
Hello D1234: Each vehicle maybe different, having different thickness of metal, and in most cases there is doubler piece of reinforcement metal in the center of the roof helping to stiffen the metal roof.
Yes a additional piece of Aluminum or Steel can be installed on the inside surface with the puck or antenna mount bolts also holding it tight against the roof metal, the added back plate can have additional bolts or machine screws attaching it the metal roof. With the antenna shown I would go with a at least 1 foot square back plate from Aluminum sheet metal, with a .1 inch thickness.
Yeah some installations even add a few machine screws to the back plate if you don't mind drilling more holes in the roof. But I wouldn't hesitate doing so if my vehicle wasn't going to the Paris Air Show.
Some of the after market puck or antenna mounts manufactures also sell back plates or doublers to reinforce the antenna mount metal.
On my old truck I have a 1 foot square piece of Aluminum for a back plate, that is installed between the metal roof and the factory center of the roof reinforcement metal with the antenna mounting bolts going thru both for added support.
wa1nic
Westfield, Ma
Tractor Supply has .062 aluminum in their stores (18x24" I think).
Ebay is filled with metal suppliers.
kf4eyr
plant city florida
delivers 1234,, check your local scrap yard/recycler yard,,, i find sheet metal of all kinds and aluminum tubing for antenna projects there,, and it is cheaper than buying it new,,
bharvey2
There are a number of A&S Metals yards in your area. I think Salinas and Watsonville would be the closest ones. They might be able to help you.
Delivers1234
Monterey, CA
Antenna, 27-30 MHz, NMO Mount, 1/4 wave, 150 W, 52.5 in. Max Height, Black Wh
Looks like this what will be installed. I'm just worried bout how flimsy it is (roof)
Delivers1234
Monterey, CA
So would the folding mount go on an NMO mount? Do you know if its the right size? I know it will be an NMO mount that is put on with the above antanne.
JayMojave
Mojave Ca
Hello D1234: yeah the Comtelco A1801AH-27 is a good antenna, using a NMO mount that will not need a back plate. There magnetic NMO mounts that work just fine with that antenna.
However any distinguished radio enthusiast should know were the local Metal Supply place is for further projects and such. They always have left over pieces of all kinds of sheet metal called remanences and you probably can go I there and just pick out what ever you want for cheap. They can cut to your needs any type of sheet metal.
Spelling, punition, word structure, and what ever else is good enough for whos it 4.
