firmware, software, mdc1200, nube with the TK-2180
NoCoFire
Northern New York
Greetings All,
I have several questions but will start with the most pressing. It looks as if you all are very knowledgeable. I just got several TK-2180's, software, and programming cable. I am trying to program them for our needs. The most pressing thing that I cannot figure out is the mdc-1200 feature. It only shows fleetsync. My software version is 1.61 and my firmware version is K1.22.00.
What am I doing wrong to not see mdc-1200 in the programming software? I have looked at other posts but it seems to me that I have a fairly recent firmware release (maybe not?) and an updated software edition (again maybe not?).
Any help that you could provide would be great. Thanks
ducksoup65
Actually the 2180 will support MDC1200 and it will work well. I believe you will need to update the firmware and your FPU software. Once updated, in the FPU, when you select your model you will also select the type of PTTID (FleetSync or MDC). Very straightforward from there. Good luck!
ramal121
Lots and lots of watts
Calif Whine Country
Both your radio's firmware and FPU are good. Click on "Model" and change signaling type to MDC-1200.
The X180 will do either MDC or Fleetsync but not both at the same time.
NoCoFire
Northern New York
Thanks It Worked!
Ramal121, fireandems13669, ducksoup65,
Thanks it worked perfectly. I still need to learn more about it but that software is excellent.
NoCoFire
