firmware update for BCT15X?
w2csx
Rochester,NY
I've notice that there is a firmware update for the BCT15X, is this worth getting?
It adds radio ID number support for MOT TRS. If you are interested in that sort of thing you might be interested in downloading and obtaining it.
safetyobc
South Arkansas
Release notes state the following changes:
What is Changed by This Update?
This update makes the following changes to your BCT15X scanner:
* Add support for storing Unit IDs in channels with alpha tags.
* Fixed a problem where corrupted memory caused by a bad PC programming upload would make the scanner lock up on the copyright screen.
* Save Hold status immediately instead of at power-down.
* Add ATT indication in Close Call Only mode.
