Firmware update tyt 390 question
mikewazowski
Forums Manager
Oot and Aboot
Thread moved. While the Tytera can be used on the Amateur Radio bands, it is not an amateur radio and this question had nothing to do with amateur radio.
Your_account
.AT
Can I use the firmware update on a TYT 390?
I would say it depend what you have.
GPS yes or no?
What many people say the Mainboard from both are the same. The only difference is GPS.
jonwienke
More Info Coming Soon!
VA
Not likely.
There are several different versions of the mainboard, some have a hardware vocoder and others with software vocoder. Then there is the GPS vs non-GPS variation. Unless the firmware is specifically labeled to be compatible with your radio (e.g. MD-390 with X.XXX series factory firmware, hardware vocoder, and GPS) you'll probably brick the radio (lock it into endless reboot loop) if you try loading it.
Read the fine print for which radios and variants the firmware supports very carefully before proceeding.
Your_account
.AT
what i remember:
380 - old vcoder
380 - new vcoder
380 - new vcoder + GPS
390
390 - with GPS
jonwienke
VA
390 has old and new vocoder, each with and without GPS. So there are at least 7 firmware variants, most of which are incompatible with each other.
Your_account
.AT
omg how to know which version I will get?
I ordered a 390 with GPS.
teufler
ST PETERS, MISSOURI
This has to do with Firmware on the TYT 390. Install went smootly, EXCEPT for one thing. The radio screen is upside down.Anyonew know how to get the screen flipped over.???
jonwienke
VA
Different hardware versions handle screen image data differently. If the firmware doesn't understand the display hardware correctly, the display will be mirrored horizontally or vertically.
jonwienke
VA
You don't. You have to check the factory firmware version when you get the radio. That will tell you what hardware variant you have.
teufler
ST PETERS, MISSOURI
screen shots of the md 390
here are some screen shots. The horizontal lines are because of my camera shutter. Unit is a md-390, purchased in dec 16
seth21w
Somewhere monitoring the air.
Saar edition is old and outdated the newest version does everything saar did plus more. I have the md390 gps vhf. foxhollow.ca look this site up the newest available update and updater are on that site pull one of each and when you unzip it will have 3 .bin files one for old vocoder one for new vocoder and one with gps! The gps is the one you want.
Your_account
.AT
So I got mine today.
The Box say AMBE+2. So in theory its the new one?
What is the right modified firmware?
390 with GPS
THX
