Firmware upgrade?
dsvm2005
Grand Haven Mi
Ok here is what I have in my scanner up boot ver:F1.1 and up Appl: U1.7 My question is do I have to first update the last version of firmware of I could go directly to the new one that was just released. Sorry for the question but I dont want to ruin my 500.00 scanner.
Thank you for the help
rdale
Lansing, MI
Firmware updates are not incremental - you always install the latest one and that's it.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
CPU U1.8 and use CPUUpdater_PSR-500-600-BootF10F11_U1.8.exe (for use with PSR-500/600 models with Boot Versions prior to 1.4)
then
DSP U1.4
judas12
Los Angeles County, CA
i have a few scanners. Is it really a need to upgrade the scanners? because i havent and they work great. What does upgrading do? I have a Pro164 Pro 162, Pro 92, Pro 96, Pro 106 BC 246, 396T, 346.
Thanks?
rdale
Lansing, MI
It depends on the scanner. Go to their support sites and see - not all can be updated.
Thanks?
This is the GRE forum .. and the upgrade that is being referred to is for the GRE scanners, specifically the PSR500/600 models. Hope this helps. Most of the scanners you have listed are Uniden models .. so I would check their site for the latest upgrades.
DonS
Franktown, CO
Actually, his listed scanners are evenly split between GRE and Uniden.
The PRO-106 should have an update coming soon. It will be based on the new PSR-500/600 update; RadioShack has the code and will be releasing it to their web site after they do their own internal testing.
rdale
Lansing, MI
i also have a PSR 300.. but i would really like to know is the upgrading. What does firmware upgrading do to the PSR 300 etc.
It depends on the scanner. Go to their support sites and see.
