AZScanner
Anyone in Phoenix got one yet? Wanna know how it does on the PRWN or RWC or WTH ever they're calling our digital system this week.
-AZ
-AZ
For 99% of P25 systems, all of the bandplan information is included in the control channel.
(The exception being a couple of military systems for which you need to enter a band plan.)
The P25 type system is not actually new, BTW. In previous models it was under Motorola (because no one else had any widespread installations). The BCD396XT properly splits it out as its own system type, not tied to Motorola.
You should note, however, that neither San Diego system is a P25 system. (I'm assuming from your location that is the system you were referring to). The DOD system is P25, but UHF.
Actually, by my term Auto Tune (center freq): I am wondering if the scanner automatically tunes to the correct center frequency (or the step increment closest to the correct center frequency), as opposed to unmuting faster on a detected signal while it may not be on the correct center frequency.Not sure what you mean here, but the Close Call tune sometimes get a false hit on a strong signal 5KHz off. Custom or Service search is right on :wink:
GREATP25 decoding sounds the best it has ever. It sounded as if the person speaking was in the next room. That clear.
That Is unfortunate.Sensitivity, unfortunately hasn't changed, at least on my 396XT vs. the classic.
How about Automatic detection of digital signals, whereas no special programming would be required to Discover digital traffic.The digital only setting works well for stored talkgroups on ID Scan (for Motorola Mixed Mode Systems) and the new NAC search addition is great.
Precisely what I said. Neither San Diego system is P25.
One immediate observation is that it's loud! One of my biggest pet peeves with the audio of the classic 396 was its quality, or lack thereof, at low volumes. There seems to be improvement in this area.
And I also agree about the volume. Heck I can have it sitting in one room and hear it in another. Great Volume.
.The volume/squelch algorithms must have been improved, it seems to work better than the 396 classic.
P25 decoding has improved...
Concerning P25 decoding, I have yet to hear any motorboating here... I am hearing a lot of P25 traffic not normally received. Signals are weak or non-existent on the signal meter, but decode is excellent...
I can't remember the last time I had motorboating on my 396XT... decode is better than my old Pro 96 and the "Classic" 396t...
.P25 decoding sounds the best it has ever. It sounded as if the person speaking was in the next room. That clear...
.In search mode, as long as you don't have CTCSS/DCS search turned on (which forces the scanner to analog only) the scanner will automatically detect/decode digital.
Weak signal is usually the cause of my dropout on P25. Do you think the sensitivity or selectivity has changed at all? I think mine is about the same.
I concur that it is about the same, perhaps a little bit better...
Does it still seem one might pick up more communications from an'other' unit with less features?Sensitivity, unfortunately hasn't changed, at least on my 396XT vs. the classic.
.You may program them in any order. However, you do need to specify the frequency's LCN when you program it in order to properly track the system.
Yay! ScannerMaster is now showing in stock on the 346XT. Placing my order now!!
Programming specific LCN order/slots -
