First part of transmission cut off
patt1345
I am installing G5 pagers with amplified base in all our stations for our move to P25 800. I have our UHF stuff programmed into it, but the first part of a transmission is cut off. The amplified base is hooked to our station am via the 6 pin DIN accessory port. Are there any settings I need to change in PPS? Thank you!
Mr_Boh
The Land of Pleasant Living
Typically this is associated with disabling the voice buffer. Even if you don't plan on recording, it is recommended to leave the voice buffer on to prevent this - I think the amplified charger makes the effect more pronounced.
patt1345
Awesome! I will give it a try thank you! I am also having issues with the pager not activating on P25 800. If I attached the profile could someone take a look at it for me? The pager activated one time, but as soon as I put it in the amplified base it will not activate. Once again thank you!
patt1345
Attached is the profile. The ultimate goal is to have a selective call channel for each station and a monitor channel. We want it to switch back to selective call after about 2 minutes for both UHF and P25. Any input would be appreciated! Thank you!
  • PDFD G5.pdf
