Tdubz6610
Is there a way to improve how the audio sounds while hosting a feed
I’m sorry but I don’t understand what you mean?Are u hosting have a link to ur feed.
It’s clear when I do not have anything plugged into it but when I have the audio cable plugged in to be able to hear it on the scanner it sounds staticyDo you hear the static when you listen to the speaker in your scanner? Is this static that you are actually receiving or is the static being introduced after your scanner?
I will try that out to turn up the scanner audio to high & yes I do have a link but the feed I run is not a very high traffic it’s here and there when a call gets dispatchedSo it sounds fine coming out of the built in speaker to your scanner but it doesn't sound good coming out of the PC correct?
First thing I would check is if you have the output of your scanner (volume) turned up to high. A lot of computers have a MIC input instead of a LINE input which is expecting a very low signal level, you might be over-driving or distorting your PC audio input.
Also could be a bad audio cable. Do you have another to try?
Do you have a link to your feed so we can have a listen and perhaps get a better idea of what is going on?
