Fixed: Issues with importing Talk Groups from RR CSV Download
w2lie
New York DB Admin
Long Island, NY
I've noticed tonight that I am having issues importing a Radio Reference CSV Dump into the Group call section of the G-Series PPS.
It looks like a heading has changed on the export, at least on the systems I am importing tonight for a customer's profile.
The issue is that the second column is called "HEX". On earlier dumps of the CSV's, the second column was called "SUBFLEET".
My workaround at this time is to open each CSV file and change the heading of the second column. This fixes the import issue.
w2lie
New York DB Admin
Long Island, NY
Can you post a link to the system in the database you are having issues with? I would like to see how it looks when I export it to a CSV file and also try to import it into my copy of PPS.
Webodisk
Silent key.
Virginia Beach,VA
It seems affect to all imports, I tried NC VIPER yesterday got same error, edited CSV header from HEX to subfleet worked perfectly
rivardj
Michigan
That second column should never have been labeled as Subfleet, not aplicable to P25 systems. Changing it to Hex and populating it with the correct data makes sense.
I discovered the change a few days ago when I tried to up date my Excel Workbook that I use to create files in the proper format for DSDPlus and OP25. It took me about an hour to update my Workbook to accept the new file format.
LEH
Yorktown, Virginia
So are you saying you got your TG file to import with 'Hex'? I messed around with two TG files last night, one with 'hex' values after the decimal and the other without any values after the 'decimal' field. If the header row had 'hex' in either case, it would not import.
I won't argue that 'subfleet' makes no sense, but that is the accepted format. Hopefully a fix to allow both may come forth (making 'hex' the preferred, but allowing older files with 'subfleet' to also still work).
jpolich7
As fmulder13 pointed out elsewhere, the problem persists. As I posted above, the fixes suggested do not work for Phoenix RWC and according to other posts the fixes do not work for them either. Appears to be a bug in the RR data files or the Unication PPS import utility.
w2lie
New York DB Admin
Long Island, NY
I was able to import the Phoenix RWC system if I modified it.
I also imported the California East Bay Regional Communications System, The North Carolina VIPER system, Wake Systems, and Durham Systems, as well as local systems in NY.
So far any system I needed to import for customers has been successful.
What if you take the systems you couldn't import and change the headers to match what can import?
What happens if you remove the HEX values completely?
Can you share what systems didn't work for you? I'd like to see if I can get them to import.
jpolich7
PPS V0.3.17 Beta4 will not import Phoenix RWC talkgroups. Error message is same as others report for other systems in other locations: data format wrong. Editing HEX and other suggestions do not help, as mentioned a couple weeks ago. Also, files posted by others that they reported as working will not import. There is a new flaw in the RR files for Phoenix RWC and some/all other systems or in the PPS software or both.
rivardj
Michigan
LEH,
I muddied the waters with my comment. My situation has nothing to do with Unication hardware or associated software. I have an Excel Workbook that I created to generate files from Radio Reference csv files that are compatible with DSD+ and OP25 systems. I had the same sort of issue as the Unication software has when the change was made to the source files from Radio Reference. I was just acknowledging the issue.
Sorry for the confusion.
KevinC
Other
Home
I just tried with the beta on RWC and it worked after I made the header change.
85425
fmulder13
Minneapolis, MN
I was able to import talk groups from Minnesota's statewide ARMER system, after using Excel to modify the "Hex" label to "Subfleet." Using Apple Numbers failed. Marking the same line "SubFleet," and "subfleet" also failed. It had to be "Subfleet" to work for me.
RFBURNS2
Monitoring is not a spectator sport.
Over here
Thanks all for the fix. Changing the header to “Subfleet“ worked for me. I use google sheets. DL file from RR. Right click file and open in notepad. Remove hex replace with Subfleet.
W4BLR
Lenoir,NC
OK Guys. Changing the header worked as far as importing the file...but...it will not import the ID tags ,HEX or otherwise. I will have to type in all the the ID's. What gives?
