Fire Rescue is testing locution on Fire Primary and 156.21.
Let us know when the feed is up.FYI I just got this setup using a RPI4 and the Broadcastify image for the calls platform. I just started seeing stuff ingested into the platform and at this time of night it's not busy and mostly the LE stuff that you can't listen too. Over the next week I'll have some higher gain antennas and time to try and find a better spot to locate them in my home.
The feed is up, and hosted on the calls platform.
As the broadcaster when I listen on the calls platform I hear a lot of the unintelligible LE and Teletype stuff which is encrypted.
The Fire and Shuttle stuff is rare but coming in broken. I spent some time looking for a better place to put the antenna I have now and didn't find a better place. An antenna with more gain and a better mounting solution show up next week. In the meantime I'll let it build a log of trunkgroups and see if the signal stays the same over the next couple of days.
my bet would be that the DSD+ problem is due to simulcasting.The Flagler Cnty P25 is Phase ll is it possible the software or apps you're using doesn't like phase ll systems? (Off the subject my county is on phase ll dsdplus has some trouble decoding it).
