Flash question
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
What are you calling a reflash? Which model radio are you talking about?
Most modern radios can be programmed with new transmit and receive info. (In the case of trunking radio, you also program the system info.) This programming requires the appropriate software from the manufacturer, the programming cable/cradle from the manufacturer, and the information on the radio system(s) to be used. (A trunking system typically requires a system key, too.)
MrAstroSaber
Walkie Talkie Man
New Mexico
I was asking for a friend of mine. I am very new to the GE Ericsson stuff. I have an Orion radio for the provoice stuff here and I have all the programing goodies and the info. As for the reflash I was not sure what he ment myself but was not sure due to the fact I am new to GE Ericsson. All my programing know how is Motorola and Kenwood. I will post more about the question when I here back from him. Thanks
mm
oregon
During the Orion radio program process you have an option of 'updating' the code file(s) in the radio.
The is all part of the Programmer software application which you use to program the Orion radio.
You will need to obtain the proper (BIZ) flash and (DSP), DSP files from harris, they end with the extension .BIZ for flash and .DSP for the Digital Signal Processor upgrade if required, and they will be something similar to the following; OG30400.BIZ (latest conventional flash) and B4R02A01.DSP (latest DSP code) for example.
When you program the radio you have an option, while in the control head programming screen/page, to select the proper .BIZ and .DSP files that are placed in your radio PROGRAMMER directory.
Mike
