Flashcodes
wacker13
Ambler, PA
If I have a flashcode that indicates I have alot more options than the radio I plan on getting cloned from, will I loose all my options, or do they not change. Thanks any info appreciated .
JohnWayne
Lynchburg, VA
You don't say what radios you are using, but I know for a fact on the Astro Sabers, the radios' models AND flashcodes have to match exactly in order to clone the radio. I would suspect this is the same on most other Flashport radios. There is nothing you can do change the flashcode in the radio, short of having Motorola do it. Chances of that are pretty slim as well.
You CAN pseudo-clone the radio by running two instances of CPS and dragging/dropping the stuff from one to the other. This will get most of your channels/talkgroups copied over with little hassle.
Another thing is that you will need a system key in order to clone the radios if they are trunked. Without the system the trunked info will NOT be cloned.
Hope that helps.
Jeff
wacker13
Ambler, PA
thanks alot for the info. That helped me out alot before it was too late. Thanks
