Flashing display on F121
radglenn
Hi!
I just had to use the "Maker Reserved" part of the Icom software to bypass the password on a pair of F121 radios I took in on trade... While that worked, I reprogrammed the for a 155 MHz frequency and on both radios I get the "blinking Display" so does anyone have any ideas? I went threw everything I could think of in the programming and can't find a thing I did wrong.....
Thank You
N2DLX
Hamilton, NJ
Looks like you lost the alignment information that was programmed into the radio. A flashing display means the VCO could not lock on the selected frequency. I did this by accident once as well, and I asked someone with a radio of the same model and bandsplit to send me their information, where I was able to correct it. Most likely, it switched the VCO type from UHF to VHF or vice versa. Start there, then look for help from someone with an identical radio.
radglenn
Thanks Rich!
That is what I was thinking too........I will start looking for someone with a stock file
Thanks again!
Glenn
Cs38614
hi i have a 210 thats doing the same thing, i erased the 3 frequencies they were in the radio was that a bad idea?
