I will listen I know my dept. is the same are u living at Blankenship. And what is your line of sight to desert Mtn. They get paged off that and I work at GNP and know if you can't get reception from that sight then hard To hear. If so can you hear any pages on your scanner. Make sure your scanner isn't set for a certain pl tone cause idk if dessert is set too 103.5 pl. also desert Has a repeater VHF that is on it maybe narrow band. You can try the UHF simcast. Channel I gave you too. Email me the address I sent you
