APX FleeBay Beauty, APX 4000 in APX 1000 case
jharr465
Niceville, FL
Looking at the eBay ad I think the seller posted an incorrect photo or two. The close up of the back of the radio with the battery removed clearly shows the radio as an APX 4000. Contact the seller if you are not sure.
K2NEC
Why is the seller of this ad selling an APX 4000 in an APX 1000 case. That does not even look close to a 4000, it definitely looks like a 1000
What makes you think it's not a 4000?
Looking at the Motorola website for the 4000, it shows that it has two knobs at the top of the radio. The radio on eBay has one.
GTR8000
NY/NJ Database Guy
BEE00
I guess you're not that familiar with the APX 1000/2000/4000 series. All are available as single-knob (Multi-Function Knob) variants, all using identical housings, and you would not be able to tell them apart just by looking at the housing. The 4000 was the first in the series to be released in 2011, originally available only as a single-knob radio. Dual knob variants came along a few years later, circa 2014.
So yes, a single-knob 4000 is going to look identical to a 1000 or 2000.
Anderegg
Enter text in this field
San Diego
Do/did they make an APX4000 with just the three soft keys and dispaly?
Paul
Giddyuptd
Here and there
Its a one size fits all with them. Slap the decal for appropriate model at factory and you're good to go. No different housing or costs with it. Then they slap the difference on you for not just for the feature set, but model printed on the emblems.
n3obl
Ø
PA
These are APX4000 single knob variant. These were surplused from Washington DC Area Metro Transit. A lot of agencies that originally bought the single knob are dumping them for the two knob variant.
K2NEC
Do you know why they are getting rid of the 1 knob radios? Why they want the 2 knobs instead. For *most* operations a 1 knob radio does what it needs to. Granted having a dedicated channel knob is nice but it isn't absolutely necessary. Is there a reason for them dumping them or just wanting to have 2 knobs?
n3obl
Ø
PA
Im just speculating but most users prefer a two knob portable as that how they always been made. I could see that multi switch wear out over time.
K2NEC
Try operating a 1 knob radio in full fire gear with gloves on in bad visibility. HINT it is all done by feel try to get that from a push button.
But we are talking about a railway here not a fire department
n3obl
Ø
PA
I just posted a reason for two knobs and why the OP did not state the radio was for rail use it was only posted where they may be from.
Thats were they ARE from. They even left programming in them when surplused.
Giddyuptd
Here and there
I know NPS had got the single knob 1000s, 4000s including some of their park fire and complaint was one would bump the top single knob down without thinking as other issues were present and turn causing the channel to change. So I cam see why they are dropping the single knob.
Public works, maybe a small time police dept would benefit for the single knob but I prefer 2 myself.
Giddyuptd
Here and there
Just my opinion but to surplus programmed radios is not wise.
This is the issue ive seen a lot lately where they will surplus and they leave it to the buyer of auction to de program but issue is it usually never happens and gets re sold to whomever sometimes mace/ucm keys loaded in.
I've seen videos where people buy old taures PD units with xtl5000s still in them loaded up, programmed and keys active.
Either some one dropped ball didnt let techs know or the idea it's old who cares we got new ones is in their head which is dumb.
K2NEC
I have never in my life changed a channel without knowing it on any radio because it isn't exactly easy to rotate a knob accidentally. Having a multi function knob would actually make it harder to change the channel because the knob first has to be pressed and then the channel can be changed. With 2 knob models, one can just change the channel as they wish.
