Fleetnet Custom Freq. Table Question
OttawaBob
Ottawa, Canada
Hi all.
Please excuse my apparent ignorance.
I have successfully (I think) programmed my BC245XLT scanner to receive the Bell Fleetnet Ontario Prov. Gov't Zone 2 System for the Ottawa area. In configuring the scanner program, I used the information from the first column of the Custom Frequency Table. I noted that there are 2 additional columns with different Base/Spacing/Offset information. Is there a reason why I should/should not try to install this information instead of the information from Column 1 in this table?
Replies may be sent simply to Bob@ottawa.ca.
Thank you.
Bob
mikewazowski
Staff member
Forums Manager
Oot and Aboot
So far the only site using one of the other two ranges is Toronto in Zone 1. You should be ok for now.
If they ever do start using Range 2 or Range 3 frequencies, you'll be missing parts of the conversation as the 245 won't do multiple ranges.
