This is the one I was referring to (known as Emergency Console Acknowledge Required):
All emergencies on Fleetnet are ACKed by the site controllers via the 308/30D affiliation function dual-OSW. For about half of them, I've also seen the 26E8 Emergency ACK dual-OSW. When seen, the 26E8 responses immediately follow (e.g. within 0.5 sec) the site controller response, which indicates that the 26E8 response is an automated response, not a dispatcher's response. I haven't seen any other form of response that could be a "dispatcher response"
Further, it looks like the 308/30D response is sent to all zones where the particular talkgroup is active (to support newer radios which can display emergency alerts), while the 26E8 response is only sent to the zone where the triggering subscriber unit is affiliated. I've seen different responses for the same radio on the same talkgroup on the same day, which suggests that it changed zones between the two emergencies. I've also seen two radios triggered at the same time on the same talkgroup, where one got a single response while the other got the dual response (from _my_ perspective).
Some logs:
Two radios, separate talkgroups, both ACK's seen for both radios:
308 I 20C9 Affiliation function; Emergency button pressed; RID=20C9 TG=224
30D I 2248
30D I 2248
308 I 20C9 ACK Emergency; RID=20C9
30B I 26E8
30B I 26E8
30D I 2248
30B I 26E8
30D I 2248
308 I 0433 Affiliation function; Emergency button pressed; RID=433 TG=22C
30D I 22C8
30D I 22C8
30D I 22C8
30B I 26E8
30D I 22C8
3C0 G 3080 SS1
308 I 0433 ACK Emergency; RID=433
30B I 26E8
30B I 26E8
30B I 26E8
30B I 26E8
Two radios, same talkgroup, different responses seen:
308 I 26EF Affiliation function; Emergency button pressed; RID=26EF TG=224
30D I 2248
30D I 2248
30D I 2248
308 I 2238 Affiliation function; Emergency button pressed; RID=2238 TG=224
30D I 2248
30D I 2248
30D I 2248
30D I 2248
30D I 2248
308 I 26EF ACK Emergency; RID=26EF
30B I 26E8
30B I 26E8
30B I 26E8
30B I 26E8
