rkillins
Is anyone using a Pro97 to monitor Fleetnet Zone 1?
I have been unable to monitor any talkgroups despite my attempts to program manually or through Win97 software. I thought I had it setup pretty much identical to my Pro96 which works fine, but obviously I've messed something up.
From what I can recall (I don't have the radio here with me as I write), but the display would flash TGIDs as though the CC was being monitored, but no audio and no programmed talkgroup labels. Primary (and alternate) control channel frequencies are programmed and set to MOT, and the Bank is set to MOT. I believe I have set up the tables correctly, but I am unsure about the steps. RR data suggests a step of .15 (a sticky here says 15 ... probably one and the same), but if I enter (Win97) .15 it defaults up to .25. Entering 15 is acceptable.
Could this be the problem? I am disappointed with the flexibility of this radio in accomodating Canadian frequency plans, so it wouldn't surprise me if this radio is incapable of accomodating Fleetnet.
Thank you in advance.
