Fleetnet Zone 2 - Kinburn Site
VA3JPX
Ottawa, Ontario
Hey folks,
For some unknown reason to me, Kinburn control channel cannot be found, even though it is strong.
Anyone else have this issue?
VA3JPX
Ottawa, Ontario
What scanner, and are you indoors?
BCD-996P2 scanner. Yes, indoors however using an antenna that use to pickup both sites no problem. Since the last download from RadioReference, the Kinburn site doesn't work. The CC is rock solid here, but the scanner has no idea what to do with it. I even tried IFX on that freq and it makes no difference.
PriorMike
Arnprior, Ontario, Canada
So, I also have a P2, with an RS centre loaded antenna on the back.
Kinburn is always 5 bars for me; although I'm not far away. However, Mount St. Pat is a problem. It'll flash 3 to 4 bars of signal, but never lock on the CC unless I stand in a certain spot or hold my hand near the antenna.
Near as I can tell, I have interference in and around my house messing with the Mt St Pat signal. Even with Kinburn, if I turn certain lights on, it won't lock on the CC even with 5 bars.
