Fleetsync and TK-3180
LSCCPR1
At my Dept. we are programming all of our portable radios, TK-3180's, with Fleetsync so we can see who is keying up each time ( on all channels we use ) and to use the emergency button feature if needed. These radios are programmed with KPG-89D software. My question is is there any way to "mute" the data burst that has bee set for the beginning of transmission from coming thru the recieving TK-3180's? Having to hear the burst (chirp) every time a radio is keyed up is getting old fast. Thanks.
n3obl
Ø
PA
I believe in the channel entry screen for each channel you need to select PTT ID mute.
I have the mdc-1200 firmware in my radios and it has that option.
Frank
Gezelle007
Lurker in the Deep
Oregon
I've tried for this option before and two people have told me that it doesn't have that feature. There is an option for muting but I think its only for BOT transmissions, so if you have one radio talking to another, it will unmute after a certain delay so that the receiving radio will "miss" the burst, I don't think it actually mutes the data though...
ramal121
Lots and lots of watts
Calif Whine Country
Motorola radios have "Data operated squelch" (DOS) that functions anytime MSK data is detected and it seems to work very well. Alas, Kenwoods do not employ this feature. But as the above replies stated, there is a ID mute feature. It is, as Gezelle007 stated, a delay in unmuting the audio so the data burst is not heard. It is enabled on a per channel basis (channel edit window) so it can be turned on only for channels that use PTT IDs. The exact timing of the delay can be adjusted in the optional features window under either the trunking or conventional tab (whichever you are using)
Of course this works only for BOT IDs. If EOT is used, you're SOL.
Gezelle007
Lurker in the Deep
Oregon
I just found something called "FleetSync Burst Noise Reduction" in the FleetSync tab. It wasn't in the older version. I haven't tried it, but this may be something to think about.
dmonty83
Massachusetts
help file
According to the "Help File" in the FPU.
FleetSync Burst Noise Reduction enables the capability to reduce the sound of incoming data burst tones when the transceiver receives FleetSync data.
When the transceiver receives an MSK data burst tone, the transceiver confirms whether or not the tone is FleetSync data. If it is FleetSync data, the transceiver mutes until the transceiver completes receiving FleetSync data.
David
MTS2000des
5B2_BEE00 Czar
the effectiveness of this feature is firmware dependent. I've had a couple of older (1.16 IIRC) 3180's that it had no effect on. Updating to 1.22 (most current) seemed to do the trick, though some of the MSK burst did come through on decode. It doesn't seem to mute MDC1200 (on 1.19 and above MDC1200 is available) like Motorola radios do with data operated squelch.
ambdrvr
TK-3180 Fleetsync
When I look in my KPG-89D software under the fleetsync option I see on the General 1 tab the option for PTT ID Sidetone. According to the help file if you uncheck the box it should eliminate the chirp you are hearing. Hope this helps.
Ambdrvr
phillmobile
bridlington, uk
Ambdrvr
tick the box to hear a beep not data, but i would always say use end of transmission not begining
