FleetSync Question
WQOC472
Okay, im getting ready to send my radio off to be programmed with some new frequencies as well as having the FleetSync PTT ID feature set up. My radio ID is 639 and the fleet number is 106. So should it look like 106-1639 on the display?? Or should it be 106-0639?? Im confused and im getting ready to send the radio shop an email with the frequency info and FleetSync info and i just need to know what to tell the radio shop and i didnt know how this all worked.
chiefwill
The fleetsync has options for alphanumeric display, but that needs to be programmed into all of the radios in the fleet. So you can have your radio ID, your name, your position...it all depends on the standards your "fleet" uses.
It depends on you as well as what chiefwill said.
I just looked at the software for mine and the highest mine will go is 4xxx.
The way i have mine setup is the base radio's are 0xxx, handhelds are 1xxx, mobiles are 2xxx. that way i ca see not only who is talking but also which radio they are on.
Just my 2 cents
73's
phillmobile
bridlington, uk
Just my 2 cents
73's
i thought radios had to be over 1000 if you set the id list it would display names on the radios not numbers
