Fleetsync with TK-5210's and KMC-38GPS setup
N6EA
I could use some help. I am working on getting some KMC-38GPS mics working with fleetsync to send position data to a custom application for Search and Rescue. I think I've got a pretty good handle on the programming needed on the portables and it looks like I am getting data and gps info on the air. Next thing I need to do is interface one of our laptops in our CP with one of the mobiles to feed the data into the app we use to track the portables. Looks like a custom DB25 to comport or usb cable will be needed. I can build it if somebody can give me a leg up on the configuration needed.
Thanks in advance.
Mark N6EA
avdrummerboy
Mohave County, AZ
What app are you using? If you want to go full Kenwood, the KAS 10 software is pretty cool, interface it with Microsoft MapPoint and you can have a full on dispatch CAD there for you. Status updates, messages, and Geotracking and Geofencing. If you use KAS 10 you can actually run it with just the cable that you use to program the radios, it'll plug right into the front of the radio and you can remotely control it and send and receive messages. It'll track the field units position when they send GPS data on transmit and you can also query the radios from the software. That would be your best bet.
