Okay, thanks. Never knew they made a dimmer for florescent bulbs.
I have another question. When I first moved into my house I installed a motion sensor light switch in the utility room so the light goes on automatically when you have a pile of clothes in your hands. Q: Can I install a florescent bulb in that?
If I am understanding the scenario correctly, you are wanting to put a
"twisty-bulb" (compact flourescent lamp) into a normal (incandescent-type) light-bulb socket, and have that on a motion-sensor on/off switch. -- It sounds like that should be okay, because the switch acts as on-off (not dimmer), just as if you swiped a normal switch with your hand.
One thing to consider is that depending on the ambient temperature in the room, sometimes
flourescent bulbs and
LED bulbs will initially not be as bright as they will be after they warm up. You can see an example of this if you use CFL bulbs in outdoor light fixtures during cold weather.
In some cases the (brief) decreased brightness can be a hazard especially around stairs, or other trip/fall hazards. -- just a thought.
Hope this helps,
