Do they speak often? I have those same frequencies in my scanner and I cannot hear a thing. Do they operate very often as well?
In my experience, they do not talk very often. If you are in the Miami area, you will need to monitor Area 18, the Everglades District. I have heard occasional radio checks from units in the field to the base, but not much beyond that.Do they speak often? I have those same frequencies in my scanner and I cannot hear a thing. Do they operate very often as well?
Thanks for the info. That is what I figured. I know for a fact that the RED CHANNEL is used as a district wide interop channel with MDFR and other agencies.In my experience, they do not talk very often. If you are in the Miami area, you will need to monitor Area 18, the Everglades District. I have heard occasional radio checks from units in the field to the base, but not much beyond that.
Whenever there is an active wildfire, you might hear more, especially on 154.265, 154.280, and 154.295, the so-called Red, White, and Blue TAC channels. I have yet to hear any traffic on the new narrow band tac channels that are listed, although that will likely change.
Just as an FYI, their Dade County repeater is located in Florida City. The Broward County repeater is located out west on US27 & Sheridan Street (they both use 159.390 MHz - pl 107.2 Hz as the repeater output). Although they both have a fairly decent coverage area, you may not hear them if you are located on the eastern parts of Dade/Broward Counties.Do they speak often? I have those same frequencies in my scanner and I cannot hear a thing. Do they operate very often as well?
They do not have much traffic but they do have routine weather transmissions as well as roll calls.[/QUOTE
Thanks for the heads up. I live in western Miami-Dade County so it should not be a problem listening to Forestry out of Florida City.
Put all of them in your scanner if you can. I live in East Delray Beach and get 159.390 really good. I've also heard activity on 159.405 and another one I cannot remember. Very little traffic unless a fire is going on. I have every frequency listed on (Florida Forest Service Scanner Frequencies and Radio Frequency Reference) in a scanner cause you never know what you'll hear.Does anyone know the Florida Department of Forestry frequencies?
